Good Afternoon,
I recently purchased a DEMOAC board, but cannot seem to get it to operate. I previously used a DEMOJM board, and wrote C code using CodeWarrior v6.3 and Processor Expert, and everything worked as expected (IO, A2D, PWM, etc.). On the DEMOAC board, I wrote a simple program, compiled, connected to the board, programmed the board, and it started immediately (it did not wait for me to press the green arrow). When I select Halt, it stops once, but seems to be stuck in the initialization code. If I continue (green arrow), it will not stop again (it just ignores the command).
I have tried downloading the code from Processor Expert (the initial code with no modifications) and it does the same thing. Downloading and running this initial code on the DEMOJM works (it doesn't do anything, but it works).
Any help or suggestions would be greatly appreciated. What is the minimum code, using Processor Expert, that will run in the DEMOAC?
Thank you.
解決済! 解決策の投稿を見る。
it seems that the problem is caused by incorrect settings of CPU component (components was formerly called beans).
Therefore could you please post here a simple project to reproduced the problem or at last settings of CPU bean and row where is the problem?
In case that you are running from external crystal, are you sure that its value on demo board correspond to the value entered in the CPU component ("Clock frequency [MHz]" property)?
What version of Processor Expert are you using?
best regards
Vojtech Filip
Processor Expert Support Team
Good Morning,
Thank you for the quick response.
I am using CodeWarrior 6.3 SE. Although my post states "newbie," I have been using Motorola/Freescale microcontrollers for many years. This includes the use of many DEMO/EVAL boards.
My past experience has been that the default configuration provided by Processor Expert can be programmed into the device, and it runs (it doesn't do anything but sit in the for loop - but it runs). The DEMOJM board worked this way.
For the DEMOAC board, however, I programmed the board with the default startup code, the debugger window appeared, and it began running immediately (the green arrow was gray). It displays:
move.w #0x2700,sr
If I halt the processor, it displays:
setReg8(SPMSC2, 0x00);
or
lea _SP_INIT,a7
If I start it again, it will not halt. It appears to be stuck in the initialization code.
I tried resetting the watchdog timer in the loop, but that did not seem to make any difference.
The startup project is attached. It should be running with the internal clock at 4 MHz bus speed (well below he limit), with the FLL engaged . Any help will be appreciated. What is the minimum stable startup configuration using Processor Expert 6.3?
Good Afternoon,
Using the v6.2 CW hiwave.exe worked, although it took several tries (it did not give me the opportunity to select the processor version on the first two tries). Thank you - I would never have found the problem. Going back to an earlier version of CW is not something that I would normally try. Interestingly, the MCF51JM part only works with 6.3 (not 6.2) when using the USB BDM programmer.
The device is:
PCF51AC256AVLKE
M60N
QAC0817
I am somewhat disheartened that this is an older device - I purchased the DEMOAC board a few days ago. I will likely order a new daughter card for the DEMOAC board. Is there some way to be sure that the daughter card I order has a newer device?
There is a problem with initial revision of chip with workaround in debugger. The support in 6.3 intended for final fixed silicon. To check whether this is the case you can try the following workaround - you can try to modify the coldfire.ini file (in prog directory, make the copy of current version).
The lines DBG_MODULE_DLL=dbgcoldfirev1.dll should be replaced with DBG_MODULE_DLL=dbgcoldfirev1_ac256.dll for sections related to AC256 and AC128 (like below, only dll name should be changed):
[MCUID7005]
;MCF51AC256A
DMM_MODULE0=FLASH 0x0 0x40000 100 5 1 2 1 1 0
DMM_MODULE1=RAM 0x800000 0x8000 101 5 0 2 1 1 0
CORE=V1
FCS=cfv1fam.fcs
[MCUID7006]
;MCF51AC128A
DMM_MODULE0=FLASH 0x0 0x20000 100 5 1 2 1 1 0
CORE=V1
FCS=cfv1fam.fcs
[MCUID700E]
;MCF51AC256B
CORE=V1
FCS=cfv1fam.fcs
[MCUID700F]
;MCF51AC128C
DMM_MODULE1=RAM 0x800000 0x4000 101 5 0 2 1 1 0
CORE=V1
FCS=cfv1fam.fcs
I have similar symptoms with MCF51AC256A and CodeWarrior 6.2.
Weird hangs like the previous poster, doesn't seem to get through the initialization.
My device came from the sample program, and is marked:
PCF51AC256ACFUE
M60N
QAA0811
Modifying ColdFire.ini as you explained above worked for me:
When I use newer chips with a different mask ID, will I have to switch back to the other DLL?
Bill
I think you should send service request.
best regards
Vojtech Filip
