Need to generate a Flat binary Image for 5282
2,291件の閲覧回数
jfint
Hello All, i'm using Codewarrior, and I'm trying to generate a flat binary image of of my target.  So far the only way that i have been able to do this is to do a memory save after programming a target with teh BDM and the .s19 file.  The "generate binary image" option in codewarrior seems to generate an image with extra information in it, in fact I hvaen't even had success using codewarrior's bdm flash programmer with this image.
I tried bincvt to convert teh s-record to binary, however this s-record generated by codewarrior is not understandable by this program.
Anyone have any ideas on how to generate a data only binary image?
Josh
2 返答(返信)
1,423件の閲覧回数
jfint
Thanks, I figured it out, and thats actually the way that I did it!
1,423件の閲覧回数
admin
Specialist II
I am simply going to suggest a tool for manupulating files in S-record and other formats:
http://srecord.sourceforge.net/
You might have more luck with it.
Cheers,
- scifi
