Creating build + MCF52233 processor + MCF52212 processor
1,211 次查看
Lakshmi
Hi, We have used MCF52233 processor for Master board & MCF52212 for Slave.
We have completed the implementation & testing of the project & now in RELEASE cycle. In the Customer's site Field Application Engineer will not be provided with the code warrior IDE to download the firmware using BDM.
We need to create a setup file, which can used to program incremental versions of firmware to the PCBs.
Could you please tell us, what are the supporting files required to create the build?
FYI: MCF52233 uses Interniche TCPIP_ClodeFire_Lite multithreading RTOS project as a code base. MCF52212 is not multithreading RTOS
5 回复数
441 次查看
scifi
Senior Contributor I
You could also implement some kind of a boot loader to support new firmware image upload using communications interfaces present on your board. It does take some effort, but it can make the firmware upgrade procedure more user-friendly.
441 次查看
mjbcswitzerland
Specialist V
A SREC loader (requires about 10k space) for these devices is available at www.uTasker.com. User's guide http://www.utasker.com/docs/uTasker/uTaskerSerialLoader.PDF
It also supports loading via USB and Ethernet (optionally encrpted) but not as stand-alone loader (requires 2k in this case).
Mark
441 次查看
MCF52233
Hi ,
u can also use CFlasher for loading program thru BDM.
u can also create separate exe file which read ur s19/Bin file and increment ur FIRMWARE VERSION or may be PCB nos. n then load it
441 次查看
Lakshmi
Thank you for the quick response.
Could you plaese tell me, where can I get CFlasher from?
441 次查看
MCF52233
