tblcf_gdi.dll  don't work
1,466 次查看
zipper
I use the CodeWarrior 7.2 and use the tblcf_gdi.dll.When I debugged,an error occured.
 The Attachment shows the error.Who can help me?Thanks very much.
标记 (1)
1,173 次查看
sergio29
:smileyhappy:
Read and respect then "CodeWarrior setup" of this document
See attached file
Sergio
13 回复数
1,174 次查看
sergio29
:smileyhappy:
See attached file
Sergio
1,173 次查看
zipper
Do you have the proper driver for the JB16 based TBLCF for CFV2 in CW7.2?
1,173 次查看
sergio29
As explained in CodeWarrior setup in "Edit" "Preferences" "Remote Connection" ,  your named
TBLCF Connection have to point to tblcf_gdi.dll and not to USBDM_GDI_CFVx.dll by cliking on "Change" and browsing
to your tblcf_gdi.dll in the correct repertory.
Your attached file show CW7.2 looking for USBDM_GDI_CFVx.dll instead of tblcf_gdi.dll.
It works perfectly for me with JB16 TBLCF
1,173 次查看
zipper
1,173 次查看
sergio29
Voici tout
1,173 次查看
sergio2985
With CW7.2, there is no TBLCF repertory under \Program Files\Freescale\CodeWarrior for ColdFire V7.2\bin\Plugins\Support\ColdFire
Freescale supplies  only Abatron, OSBDM and PEMicro repertories.
Where have you found all your TBLCF files ?
1,173 次查看
zipper
Then what's the version of CW that you are using for coldfire V2?
1,173 次查看
sergio2985
I'm using TBLCF for Coldfire V2 MCF52236 and MCF5271 with  CW7.1 or CW7.2 with success
1,173 次查看
zipper
I am wrong.Now I know those files are not tblcf files.They are for TBDML,not for JB16 based TBLCF.
Bestregards
zipper
1,173 次查看
zipper
I made a folder named tblcf.Maybe tblcf does not work in CW7.2.I will try it in CW7.1.Thank you very much.
Bestregards
zipper
1,173 次查看
zipper
Hi,I did as what you said,but it still won't work.I found a lot of dlls and none could work properly.I think my driver for the TBLCF may not be corrretly installed.Do you have the driver for TBLCF?I can't find other driver on the Internet.
Bestregards
zipper
1,173 次查看
zipper
:smileywink: Do you have the proper driver for the JB16 based TBLCF for CFV2 in CW7.2?
1,173 次查看
zipper
Hi,my device is TBLCF that is based on JB16 for CFV2,I got a driver and installed it.But the CW7.2 can't dectect it.
