All.
i'm using Codewarrior for Freescale MPC55xx v2.8 targeting the MPC5566 CPU.
I have a sample project building in the CW IDE and would like to generate a makefile from the current project settings so that i can extract the compiler and linker settings to then build outside the IDE using the command line tools. How can i do that?
i see references in other forum entries about using Project->Export .... but don't see that available in the CodeWarrior for MPC55xx/56xx v2.8
thanks
Rob
