Conditional Compiling
4,232件の閲覧回数
timotay01
Is there a way to setup a conditional compile for the entire project typically done in a make file with -D ?
タグ(1)
4 返答(返信)
644件の閲覧回数
CrasyCat
Specialist III
Hello
Which processor are you targeting (HC08, HC12, ...)?
Are you planning to build from the IDE or from a make file?
CrasyCat
644件の閲覧回数
timotay01
Sorry, build from IDE, and part is CF5208
644件の閲覧回数
CrasyCat
Specialist III
If you are using CodeWarrior for Coldfire V6.x you can just add the #define corresponding to the macro you want to define in the target settings "C/C++ Preprocessor Panel".
This panel can be found in the target setting dialog. Press ALT + F7 to open the dialog.
If you are using an older version of the tools, you have to go through a prefix file.
A prefix file is a header file which is included in each ANSI C source file.
Macros are defined there using #define and you specify the name of your prefix file in the target "C/C++ Language Panel".
I hope this helps.
CrasyCat
644件の閲覧回数
timotay01
Yes that was what I was looking for thanks.
