SREC Output Missing a Line
989件の閲覧回数
pk2
I am using CW 10.4 but this problem seems to be common to previous versions I have tried too.
When producing a .srec output file there is a section of the output with a line missing.  For example:
S2140003F09D0500009D0500009D0500009D05000070
S214000400FFFFFFFFFFFFFFFFFFFFFFFFFEFFFFFFF8
S21400042001DF704701DFFFF7FEBFD148006872B6F4
S214000430018B39B9416AC269D369994200F00280DA
Careful examination of the above shows that the line that should begin with S214000410... is missing.
Generating a binary out produces this:
0003F0:  9D 05 00 00 9D 05 00 00 9D 05 00 00 9D 05 00 00
000400:  FF FF FF FF FF FF FF FF FF FF FF FF FE FF FF FF
000410:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000420:  01 DF 70 47 01 DF FF F7 FE BF D1 48 00 68 72 B6
Note that the missing line should be all zeros.
Why is this missing in the .srec output file?  I have to edit the srec file to add the missing line so when using the KwikStik - EZ port programmer described in AN4406 the part programs correctly.
Is there a way to make CW produce the correct output file?
730件の閲覧回数
BlackNight
about the extension: this is problem of some GNU tool integration (including the one used in CodeWarrior).
See http://mcuoneclipse.com/2014/04/11/gnu-additional-tools-create-flash-image-print-size-and-extended-l...
The GNU ARM Eclipse plugins in KDS or the ones which you can use with stock Eclipse (e.g. Kepler) do not have this issue.
See http://mcuoneclipse.com/2014/04/20/binary-files-for-the-mbed-bootloader-with-eclipse-and-gnu-arm-ecl...
I hope this helps,
Erich
3 返答(返信)
730件の閲覧回数
TICS_Fiona
The latest version is v10.6, could you please check whether the same problem also exists on v10.6? CW 10.6 can be downloaded from:
http://tinyurl.com/6jo5tge
If the problem also exists on CW10.6, please attach a simple project to help us reproduce the problem, thanks!
730件の閲覧回数
pk2
I tried ti install CW10.6 but my virus software reported a problem with it.  Can you try it in CW10.6?  The "Hello" example for a tower can be used to see the problem.
Also... when selecting output file formats.. wy are all the extenisons .hex rather than what the file actually is.  I.E.  when I select a binary file out I would expect a .bin extension.
731件の閲覧回数
BlackNight
I hope this helps,
Erich
