S12X CW4.5 function pointers
4,070件の閲覧回数
gravity
S12XDP512, CW 4.5, LARGE memory model
I have a function pointer defined as
typedef void (*function)(void);
I have a void pointer which is holding the function address  0x7DB089'G ( which is actually laid out in memory as B0897D.
When I attempt to cast it (or call it) the runtime GLOBAL_TO_LOCAL function is called. The result is
0x7DC289 (or  C2897D as laid out in memory). This is incorrect and crashes the code.
Any suggestions how I can get around this. I'm guessing that the routine assumes this is a data pointer and not a function pointer?
Cheers
タグ(1)
7 返答(返信)
664件の閲覧回数
gravity
S12XDP512.
The problem was that I was passing the function pointer around using a "void*". I had made this "void*" a "void* far", so it was casting it to global addressing.
Cheers
M
664件の閲覧回数
CrasyCat
Specialist III
Hello
 Is the problem fixed now?
 If not, can you send me a code snippet reproducing the trouble.
CrasyCat
664件の閲覧回数
CrasyCat
Specialist III
Hello
Which CPU are you currently using (HCS12XDP512, ....)?
From what I can see (from HCS12X reference manual), address 0x7DB089'G is in fact equivalent to address 0xF6B089'L.
All absolute addresses you specify in ANSI C source code are considered as logical (even in large memory model).
So instead of writing
 function func;
  func = (function) 0x7DB089;
 func();
 You have to write
 function func;
  func = (function) 0xF6B089;
 func();
CrasyCat
664件の閲覧回数
gravity
I think my problem is S12X specific and is to do with translating from a Global address to a local address.
The global address is 0x7DB089'G but the local address becomes 0xF6C289'L
664件の閲覧回数
gravity
I compiling using large memory model, so I thought everything is a far pointer?
664件の閲覧回数
Alban
Senior Contributor II
Sorry, but I can't confirm...
664件の閲覧回数
Alban
Hi Gravity,
When you use external address space, you need to use FAR pointers to indicate to the debugger which space you address and avoid address to be truncated or wrong.
See Nabla's post and the code I had on the NE64 with extended bus.
If I understood well what you meant...
Alban.
