How to trim SH8 mcu for 20 MHz bus within PE (CW 10.6)
713件の閲覧回数
Rob23
When using PnE programmer I can select algorithm which will trim the MCU for 20MHz bus from internal clock. How can this be done when using CW 10.6 debugger/programmer?
456件の閲覧回数
david_diaz
Hello Rob,
I recommend the following document in order to trim your device:
Trimming the S08P MCU
The document mentions the S08P family, but it is the same procedure for the S08SH.
Hope this information will be useful for you.
Have a great day.
Best Regards, :smileyhappy:
David Diaz.
