How to plugin Rational ClearCase in CodeWarrior 10.6
1,231 次查看
sakthivelkuland
I'm using CW10.6 version for my TPMS Development, I have lots of source files to maintain, so I want to use the clear case version control for ChekIn and CheckOut function and all other functions for organize my project.
I have searched online but I'm not getting the proper guidance to plugin the clear case. If anyone has already working environment please share a document for a plugin ClearCase or any other related documents.
I have found the document for the CW10.3, I have followed the guidance at end of the process connect error, see the below figure:
I don't have any how to resolve this issue, this will be very grateful if anyone helps me on this. Thanks in advance.
Regards & Thanks,
Sakthivel K
标记 (1)
4 回复数
857 次查看
sakthivelkuland
Hello Alice,
Thanks for Information,
When Install the IBM Rational ClearCase SCM Adapter it  pop Up security Warning
Still, I have press OK to continue, Once Installation complete CW restarted,
Once I selected Pop up below
I have the same problem still existing. Unluckily My system is Window 64Bit Operation system.
I think you can also ask help from IBM support for further.
857 次查看
sakthivelkuland
Hello Alice,
Thanks for your response. Yes, I have tried "http://eclipse-ccase.sourceforge.net/update/" Also but then I'm not getting the "ClearCase" Menu of menu tools. Again I will try this link.
Document Number: AN4753 (Rational ClearCase Use in CodeWarrior 10.3)
Thanks in advance.
857 次查看
Hello sakthivel,
Thanks for your sharing.
I recommend you refer to the steps IBM provide to install :
IBM Rational ClearCase SCM Adapter (For Eclipse), Version 7.6.2.0 - United States
Also please pay attention your PC system, if 64 bit, there is a thread you need to have a look:
IBM About SCM Adapter support on 64 Bit operating Systems - United States
If still have problem when install it, I think you can also ask help from IBM support, they may know it more clearly.
Hope it helps
Alice
857 次查看
Hello sakthivel kulandaivel,
- How about use this update site :
(From this thread https://community.nxp.com/message/526649 )
- "I have found the document for the CW10.3," could you please show which DOC ?
Hope it helps,
Alice
