Crash with CW 6.2.1 when compiling for 51AC256
1,763件の閲覧回数
Kopone
I just got a DEMOAC board and downloaded the latest CW SE 6.2 plus the MCU 6.2.1 compiler patch.
I started a little test application running an LCD. However, when trying to make the project, the compiler crashes at a point where an int has to be converted to an unsigned char (I tried quite some tricks with passing the value through dummy variables etc).
The messagebox says:
"MW C/C++ E68K encountered an unhandled exception 0xc0000005 at address 0x06724986
(The memory at address 0x00000028 could not be written)
Crash dump writen to C:\...."
Is there anyone I can send this crashdump or even the (small) project to, to get this issue sorted out?
Edit: CW 6.1 from the devkit DVD does not crash
 Sven
Message Edited by Kopone on 2008-08-19 12:43 PM
タグ(1)
494件の閲覧回数
CrasyCat
Specialist III
Hello
Compiler crashes need to be investigated by our support team. I would recommend you to submit a service request for that.
Click here to submit a service request.
Make sure to attach a reproducible project and installed product information to the service request.
To generate the required information:
- Start CodeWarrior
- Open the project
- Select "Help" -> "Pack and Go" and follow instructions on the screen.
Attach the generated .zip file to the SR.
CrasyCat
2 返答(返信)
494件の閲覧回数
Kopone
Thanks, I'll send it to them.
Sven
495件の閲覧回数
CrasyCat
Specialist III
Hello
- Start CodeWarrior
- Open the project
CrasyCat
