CodeWarrior does not flash K20DX32 properly
587件の閲覧回数
gerryk
I have built a simple program and it will run and debug fine, but when I flash it the device, it does not work,
Here is the output of the flash console:
fl::target -lc "Flash Arm"
fl::target -b 0x1ffff000 0x2000
fl::target -v off -l off
cmdwin::fl::device -d "FTFL_PFlash32S1RAM8" -o "8Kx32x1" -a 0x0 0x7fff
cmdwin::fl::image -f "D:\\CSSD Documents\\Apparata\\500RackFirmware\\Arm\\Code Warrior\\V0-0\\Rack500-V0-0\\FLASH\\Rack500-V0-0.elf" -t "Auto Detect" -re on -r 0x0 0x7fff -oe off
cmdwin::fl::erase image
Beginning Operation ...
Auto-detection is successful.
  File is of type Elf Format.
Performing target initialization ...
Downloading Flash Device Driver ...
Reading flash ID ...
Erasing Sector 0x00000000 to 0x000003FF
Erasing Sector 0x00000400 to 0x000007FF
Erasing Sector 0x00000800 to 0x00000BFF
Erasing Sector 0x00000C00 to 0x00000FFF
Erasing Sector 0x00001000 to 0x000013FF
Erasing Sector 0x00001400 to 0x000017FF
Erasing Sector 0x00001800 to 0x00001BFF
Erasing Sector 0x00001C00 to 0x00001FFF
Erasing Sector 0x00002000 to 0x000023FF
Erasing Sector 0x00002400 to 0x000027FF
Erasing Sector 0x00002800 to 0x00002BFF
Erasing Sector 0x00002C00 to 0x00002FFF
Erasing ...
Erase Command Succeeded
cmdwin::fl::write
Using restricted address range 0x00000000 to 0x00007FFF
Programming file D:\CSSD Documents\Apparata\500RackFirmware\Arm\Code Warrior\V0-0\Rack500-V0-0\FLASH\Rack500-V0-0.elf
Downloading 0x000000F8 bytes to be programmed at 0x00000000
Executing program ....
Program Command Succeeded
Downloading 0x00001310 bytes to be programmed at 0x00000400
Downloading 0x00001310 bytes to be programmed at 0x00001710
Downloading 0x000004C0 bytes to be programmed at 0x00002A20
cmdwin::fl::device -d "FTFL_DFlash32S1RAM8" -o "8Kx32x1" -a 0x10000000 0x10007fff
cmdwin::fl::image -f "D:\\CSSD Documents\\Apparata\\500RackFirmware\\Arm\\Code Warrior\\V0-0\\Rack500-V0-0\\FLASH\\Rack500-V0-0.elf" -t "Auto Detect" -re on -r 0x10000000 0x10007fff -oe off
Image size is 0 bytes, nothing to erase.
Nothing to erase.  No sectors selected
Erase Command Succeeded.
cmdwin::fl::write
Using restricted address range 0x10000000 to 0x10007FFF
0 Bytes Programmed, Check Restricted Address Range
I can't tell if the device was flashed correctly or not, but in any case the program does not run from flash......
タグ(1)
336件の閲覧回数
ZhangJennie
hi,
can you pleases check if this solution can help?
Re: MK10DX256VLK7 doesn't run standalone, just when debugging. Verified it's running from FLASH, not...
Zhang Jun
