Code Warrior 10.2 Build bug
595 次查看
Jep
Hello again.
Quick question here concerning the build operation .. hopefully someone can provide an answer.
I write code with Code Warrior 10.2 in Assembler with absolute.
So I have two source files a Main.asm and MCUinit.inc include.
I have this problem .. IF I alter the MCUinit code and then build the code CW doesnt build the new code with the MCUinit changes included.
I have to edit the main.asm and I usually just create an error by adding a letter to the end of a variable and then perform a build.
CW flags the error and I simply delete the added letter and rebuild .. Then it rebuilds and includes the changes made to the MCUinit.inc file.
I know this is not huge but it is sometime annoying and I just thought I would see if anyone has any advise.
Thanks in advance
Jeff Kopittke
标记 (1)
371 次查看
BlackNight
the thing is: the assembler does not produce a list of include dependencies for the make utility (the C/C++ compiler does).
As such, the make file has no dependency to the .inc file, just to the .asm source file:
# Tool invocations
abs.obj: $(ASM_SRCS)
So with this, the make does not realize that changing the .inc needs to assembly the main.asm.
Several 'solutions':
- 'touch' the main.asm file: you do not need to add an error: simply makes sure it gets a file date newer than the object file
- do a Project > Clean with a build
- Alternatively you can create make targets 'clean' and 'all' in the Make Targets View. Details in the link below.
- create your own make file: this might be helpful: Make my Make with Eclipse and MCU10 | MCU on Eclipse
Hope this helps,
Erich
371 次查看
Jep
Thank you for taking the time to answer Erich .. I will try the touch method
Jeff Kopittke
372 次查看
BlackNight
# Tool invocations
Hope this helps,
Erich
