Hi there,
Using Cw 10.3 on a DSC target with Multilink Universal. If I click "Step over" it actually does "Step into". Is this a bug or am I doing something wrong?
It doesn't work even if I have no breakpoints set. Sometimes it does work, but I haven't figured out under what circumstances.
For now, I have gone back to CW 7.3 with USB TAP which is slow but reliable.
The limit is in the microcontroller (number of hardware breakpoints).
You get a higher limit if you debug/run your software in RAM.
