hi
i have centos 6.5(final) on virtual machine and i want to run ltib on it. after running ./install script,when i run ./ltib script, there is following error :
ltib cannot be run because one or more of the host packages needed
to run it are either missing or out of date.
Please install/upgrade these packages and then re-try.
Package Minimum ver Installed info
glibc-devel 0 not installed
rpm-build 0 not installed
Died at ./ltib line 1265.
traceback:
main::host_checks:1265
main:479
Started: Tue Jul 28 16:54:39 2015
Ended: Tue Jul 28 16:54:40 2015
Elapsed: 1 seconds
Build Failed
but it seems that i have the packages.when i run yhe following command : sudo yum install glibc-devel ,there is :
Loaded plugins: fastestmirror, refresh-packagekit, security
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: mirror.vit.com.tr
* extras: mirror.vit.com.tr
* rpmforge: mirror.smartmedia.net.id
* updates: mirror.vit.com.tr
Package glibc-devel-2.12-1.149.el6_6.9.x86_64 already installed and latest version
Nothing to do
what is the problem?!
plz help me
thenks
mohammad
解決済! 解決策の投稿を見る。
i switched to fedora fc 6 and it is easily done !!
thanks for your help , Pascal .
To investigate the problem, we need to know exactly the CodeWarrior version you're using.
To do that you must:
Under CodeWarrior IDE (classic)
Start the IDE and click on Help | About Freescale CodeWarrior.
Click on Installed Products
Provide us all info displayed.
Or you can save them in a txt file.
Under Eclipse IDE
1- Start Eclipse and click on Help ¦ Freescale Licenses
The Status column gives the status of the license.
Under Product, select it and click on details.
A new dialog show up giving license details.
2- Start Eclipse and click on Help ¦ About CodeWarrior Development Studio
Under Installed Products, you will see the version used.
If the Installed Products is not available for older version you should find information in the welcome.txt
under the installation folder.
In case of MQX, please provide us the MQX version used ?
In case of BSP, please provide us the BSP info, the target and the chip used ?
In case of Ltib or PCS please provide us details about that ?
Another important information is the processor you're using.
Pascal
Freescale Technical Support
hi
i have codewarrior on windows but i don't have it on linux.
you mean i have to install codewarrior on linux ?
is it necessary for running ltib?! ( because i think the codewarrior on windows has no impact on installing ltib )
We just need to know exactly the tools you're using.
Pascal
