I develop application in code worrior 2.10.in debug mode when i try to modify flash memory location i cant from memory window.
Hello Karan
When debugging in CodeWarrior, user can only modify the data in RAM from memory windows, cannot modify the flash memory.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Yes but I don't think you can do that by changing the code directly in the memory component.
Now I think you could access the Flash in your application.
Most of the time there is a process/rules to follow to be able to access the Flash.
When you load the application on board (Flash), the flash programmer is used in order to access the flash programming, to erase the code, to flash the application and to verify the loaded application.
If you want to access the flash memory via your application, I recommend you to refer to the the device manual.
The process/rules for flash should be explained.
Pascal
Freescale Technical Support
