can anyone send me kinetis L emmulate eeprom sample code under Codewarrior? I referred an2296, the program routine works under IAR, but can't under Codewarrior.
636 次查看
hotashu
hello,
can anyone send me kinetis L emmulate eeprom sample code under Codewarrior? I referred an2295sw, the program routine works under IAR, but can't under Codewarrior10.6.
after copying flash routine from rom to ram, FLASH_FlashCommandSequence can't work, program got fly everytime when run this code.
anyone please send me a demo code on Codewarrior KL flash programming is very appreciated.
388 次查看
ZhangJennie
hi hotas,
FLASH_FlashCommandSequence is copied to RAM flash programming routines. from my experience, the CW version flash programming routine code size is larger than IAR version's, increase buffer[128] to buffer[200] to make sure all the flash programming routine is copied to RAM. please try it.
Zhang Jun
388 次查看
hotashu
I followed your suggestion that solved our problem.
