Trying to connect P2020 on custom board with CodeWarrior and CWTAP. An error is appearing: CCSProtocolPlugin : Failed to reset the target  [CCS last error: Draco/m HIP8: ELF is not in expected HALT mode ]
2,401件の閲覧回数
igorvereshchagi
Hello
What I need to check to fix this error?
タグ(3)
8 返答(返信)
1,410件の閲覧回数
marius_grigoras
Make sure you have the DIP SW settings set up as for P2020 and not for P2010 (details are in the CW stationary project).
Marius
1,410件の閲覧回数
igorvereshchagi
Hi, Marius
Help me, please
Here is ccs log
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 10
    Error message: Connection refused
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 0
ccs_get_connection_count
    serverh = 0
    count = 1
    ccs_get_connection_count; ccs_error = 0
ccs_available_connections
    serverh = 0
    count = 0
    ccs_available_connections; ccs_error = 0
    serverh = 0
    count = 0
ccs_config_cc
    serverh = 0
    config_string = cwtap:10.1.1.115
    ccs_config_cc; ccs_error = 0
    serverh = 0
    count = 1
ccs_set_timeout
    serverh = 0
    timeout = 15
    ccs_set_timeout; ccs_error = 0
ccs_cc_status
    serverh = 0
    cc = 0
    ccs_cc_status; ccs_error = 0
ccs_cc_version
    serverh = 0
    cc = 0
    version.major = 0
    version.minor = 0
    ccs_cc_version; ccs_error = 0
ccs_set_timeout
    serverh = 0
    timeout = 15
    serverh = 0
    count = 1
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 0
    value = 1000
    ccs_config_server; ccs_error = 0
ccs_get_config_chain
    serverh = 0
    device_list: (size = 0)
    ccs_get_config_chain; ccs_error = 0
ccs_config_chain
    serverh = 0
    cc = 0
    device_list: (size = 1)
        device[0]:: core_type=mpc8572(102)
    ccs_config_chain; ccs_error = 0
    serverh = 0
    device_list: (size = 3)
    serverh = 0
        device[1]:: core_type=Draco/m HIP8(53)
        device[2]:: core_type=Draco/m HIP8(53)
ccs_send_message
    coreh = [serverh:0;cc_index:0;chain_pos:1]
    message = 3
    ccs_send_message; ccs_error = 0
ccs_stop_core
    ccs_stop_core; ccs_error = -2147418099
    Error message: ELF is not in expected HALT mode
ccs_read_register
    index = 287
    count = 1
    size = 4
    value: (size = 4)
         00000000
    ccs_read_register; ccs_error = -2147418098; duration=10 ms
ccs_reset_to_mixed
    chain_pos: (size = 3)    { 0 (halt) 1 (run) 2 (halt) }
    ccs_reset_to_mixed; ccs_error = 39; duration=2810 ms
    Error message: Draco/m HIP8: ELF is not in expected HALT mode
ccs_get_subcore_error
    serverh = 0
    cc = 0
    error = -2147483635
    chain_pos = 1
    ccs_get_subcore_error; ccs_error = 0; duration=0 ms
    serverh = 0
    count = 1
ccs_delete_cc
    serverh = 0
    count = 0
    ccs_delete_cc; ccs_error = 0
ccs_kill_server
    serverh = 0
    ccs_kill_server; ccs_error = 0
1,410件の閲覧回数
marius_grigoras
I think the board is a custom one and not freescale specific. Using the P2010 SoC from CW connection is changing something?
Thank you,
Marius
1,410件の閲覧回数
igorvereshchagi
Seems to be HW problems, suggesting TRST line do not contacting to chip
Checking this point
Thank you
1,410件の閲覧回数
igorvereshchagi
Yes, the board is custom
I have tried to use P2010 option in connection settings, nothing changing
Thank you
1,410件の閲覧回数
igorvereshchagi
There are a lot of config pins may be pulled high or low
Which of them are significant for this issue?
1,410件の閲覧回数
igorvereshchagi
I have no DIP switches on the board
Which pins must be checked?
261件の閲覧回数
D15
May I ask if the issue has been resolved? I am currently experiencing the same problem as you.
