Hi, i am new in the Qorivva microcontroller and i want to start with the TRK 5604B, but there people saying me that i can not program the micro if i have not a BDM..
Is true what i need the BDM for program the micro, i simplify connect the board to the computer with the USB cable directly???
this is the device what i need??
greetings...
解決済! 解決策の投稿を見る。
Hi Jose,
I don't have the board on my side but the TRK-MPC5604B: MPC5604B StarterTRAK (Development Kit) should contains all cables to use it.
According to the Quick Start http://cache.freescale.com/files/microcontrollers/doc/user_guide/MPC5604BQSG.pdf, the board includes OSBDM:
On-board JTAG connection via open source OSBDM circuit using the MPC9S08JM microcontroller
The TRK-MPC5604B package includes the following items:
• TRK-MPC5604B Board
• CodeWarrior Development Studio DVD-ROM
• TRK-MPC5604B Resources CD
• USB A-to-B Cable
• Freescale Warranty Card
The USB A to B cable is using the OSBDM interface.
I will check with my colleague and will keep you updated.
However, following the info I found, it should work.
Pascal
the MPC9S08JM microcontroller need burn firmware or not? if need where is the firmware?
Just got info from colleague.
OSBDM/OSJTAG interface works with CW for MCUs v 10.x
You don't need Multilink interface.
Pascal
Hi Jose,
• USB A-to-B Cable
Pascal
