I am programming HCS08 series controller. While create project i Selected create check box, then also it says not found.
Plz help, Thanks in advance
Hi Valecha,
Could you tell us which CodeWarrior version are you using? Have you modified the project files outside the IDE?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
