Looking in the documentation there shall be a tab whilst in debug mode where this can be disabled but that tab does not exist in our version? Codewarrior MCU (Eclipse), version 10.6, build 140329. Target: MPC5643L.
User can skip the breakpoint from the <Run> menu->Skip all breakpoints. And to show the breakpoints existing in the project, please open the Breakpoint View from <Windows> menu->Show Views->Other, then extract ‘Debug’ to find ‘breakpoints’.
Fiona Kuang
Technical Information & Commercial Support
Thank you for your reply. The list of breakpoints are found the way you describe but the breakpoints causing the issue are not present in that list.
It seems as each interrupt in the CPU is what causes the unwanted and invisible breakpoints while debugging but *only* when single stepping, not when running. Does anyone recognize this issue?
