FreeMASTER crash when configuring Packet Driven BDM communication plug-in
808件の閲覧回数
daniel_aciubota
FreeMASTER crashes when I try to configure the "FreeMASTER Packet Driven BDM Communication" Plug-in.
In the "BDM cable Settings" menu if I click a different option than the default one the program crashes (exits without any message).
I have this issue using FreeMASTER versions 2.08, 2.09 and 1.4.4 on a system with OS Windows 10 Pro version 1803.
タグ(3)
2 返答(返信)
579件の閲覧回数
daniel_aciubota
The crash was caused by the debugger (P&E Micro) drivers.
An update of the drivers solved the issue.
(The USB Multilink driver version that works is 12.7.0.0 )
579件の閲覧回数
guenter_loettrich
Hi all,
in my case it seems to be related to the build of the used Windows 10 version.
Windows 10 Enterprise, Version 1709 works ok but version 1803 doesn't work.
