Firmware Update
Firmware Update
993件の閲覧回数
peterascott
When I debug my application via CodeWarrior over a Multilnk Universal FX cable, I get an error message:
Flash Erase Failed. Result = $8882 Firmware update failed. Retry?
If I say 'No', I am able to connect and successfully debug my application. But why am I seeing this error? I have programmed it through the PE tool so not sure why it is trying again.
Pete
4 返答(返信)
978件の閲覧回数
ZhangJennie
Hi peterascott,
What's your target part number?
We need to make sure Multilnk Universal FX firmware support the specific PN,
I suggest you downloading USB Multilink Resources Installand update the firmware on Multilnk Universal FX firmware to the latest and supporting the specific PN
https://www.pemicro.com/downloads/download_file.cfm?download_id=346
Have a nice day,
Jun Zhang
973件の閲覧回数
peterascott
I am targeting the MPC5675k and when running the firmware update tool, I select the Qorivva MPC5xxx for the "Architecture to Support". This successfully updates to the 11.9 version. But when I run the debugger I still receive the same error. While it does work if I indicate No to retry, I am wondering why I get this error.
Pete
609件の閲覧回数
0点过后必饿
Hello, I have met the same problem as you, and the steps you tried to solve the problem are the same, and the final result is the same. May I ask whether you successfully solved the problem at last?
600件の閲覧回数
peterascott
I have not been able to resolve the issue, I just do the 'No' option and things work.
