Did you know that the CodeWarrior IDE includes assemblers that support several specific processors?
Well, it does, and for you, codewarrior programmer this is one of its many cool tools to develop great code!
Today I found this manual that helps us out and explains the corresponding assembly-language syntax and IDE settings for these assemblers, in this case, thesyntax for assembly-language statements that the CodeWarrior assemblers use.
These explanations not only cover simple statements, they also include macros and directives!
You might be thinking, "dude, all the assemblers share the same basic assembly-language syntax!".
I won't argue that, it's true, but instruction mnemonics and register names are different for each target processor.
To get the most from this manual, you should be familiar with assembly language and with your target processor, so I'd
recommend you to start getting into this whole low-level programming style!
Unless otherwise stated, all the information in this manual applies to all the assemblers, enjoy!
