CMSIS and Codewarrior
1,302件の閲覧回数
tobiashofbaur
for an ARM Cortex M4 project, i want to use the CPU specific instructions for sqrt using the ARM Toolchain  with the ARM Compiler.
I can sucessfully include CMSIS into the project, however, it seems, that the necessary macros are not generated (e.g. compiler etc.)
Moreover, if I strip everything unnecessary from CMSIS and onyl include the bare VSQRT in the syntax of CMSIS
      __asm("VSQRT.F32 %0,%1" :  "=t"(*pOut) : "t"(in));   (wrapped in a function)
the compiler complains about the constraints.
Do you know what is going wrong, or what I have to change? Unfortunately i cannot find a detailed documentation on the Freescale Arm Compiler or the vsqrt.
Tobias
タグ(2)
6 返答(返信)
988件の閲覧回数
Carlos_Mendoza
Hi Tobias,
Which Cortex M4 MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
988件の閲覧回数
tobiashofbaur
Hi Carlos,
thank you for the reply.
It is a MK70FX512VMJ15
988件の閲覧回数
Carlos_Mendoza
Hi Tobias,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains the usage of the ARM CMSIS Libraries with Kinetis in CodeWarrior:
Tutorial: Using the ARM CMSIS Library | MCU on Eclipse
Hope it helps!
Carlos Mendoza
988件の閲覧回数
tobiashofbaur
Hi Carlos,
I followed that example, and it works as far as it is applicable. However in our project we cannot use the GCC compiler, but have to use the Freescale ARM Compiler ( mwccarm )
It seem, this does not generate the necessary macros for cmsis to work/ does not recognize the cmsis syntax.
Best
Tobias
988件の閲覧回数
Carlos_Mendoza
Hi Tobias,
Which errors are you getting? Could you share an example project so I can replicate this on my side?
Thanks in advance for your response!
Carlos Mendoza
988件の閲覧回数
tobiashofbaur
Hi Carlos,
I attached a minimal "working" example. The project has the same setting as our main project.
As it is, it does not compile. If I comment the asembler line, it does compile.
If I change the compiler to ARM Ltd Windows GCC Compiler, it does compile with the asembler line.
Thank you for your help
Best
Tobias
