我用codewarrior V8.2 for 56800E,其中用到函数,函数定义在单独的头文件里,但是在中断事件events里调用,显示几个函数没有定义!应该如何处理??
liguohongliguoh
TICS_Fiona
Hello liguohong,
Whether you have included the head file which defined your functions?  Usually we define the function entity in C file, and declare it as external function in head file. Then include the head file in the C file which calls the function.
Hope this helps! If not, please attach your CodeWarrior project. Thanks!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
