Turn off register variables for debugging
2,598件の閲覧回数
sellynny
How can I turn off register variables for debugging?
6 返答(返信)
720件の閲覧回数
jag
put the "volatile" keyword before the variables you want to see in the debugger.
Bye Jack
720件の閲覧回数
J2MEJediMaster
Specialist I
I am not sure what you mean here. Are you talking about the debugger display, or how the compiler generates code? And what hardware target and Codewarrior version are you using?
---Tom
720件の閲覧回数
sellynny
My problem is that I have the same code running on Visual studio and it's fine. The same code running on CW doesn't have the good result. I tryed to debug step by step to compare but on CW I can't see some variables. In the debug window I have the wrong address for some variables (two different variables have the same address and nothing inside).
720件の閲覧回数
J2MEJediMaster
Specialist I
It sounds like you need to turn off all of the compiler optimizations in CodeWarrior. The optimizer will make statements and variables move about or disappear.
---Tom
720件の閲覧回数
sellynny
I already did it but nothing change.
720件の閲覧回数
CompilerGuru
Please provide more details, for example which architecture you are using.
I want to avoid to give a tip for a coldfire compiler switch when in the end you are using a S08
(or something else).
See:
http://forums.freescale.com/freescale/board/message?board.id=CWCOMM&message.id=3819
