OLED Driver source code
5,013 次查看
zoids
Does anyone here knew where could I download this zip file(AN3415SW.zip) containing the sample OLED Driver source code? This is mentioned in the documentation entitled "OLED Display Driver for the
HCS08 Family" OLED Driver Demonstration for 4 Bits-per-Pixel Displays.
Thank you...
587 次查看
Alban
Senior Contributor II
Hello Zoids,
There is nothing as efficient as using the Search Engine (top right) with a proper keyword...
For instance, using AN3415SW gives:
Software to Accompany AN3415 | Documentation | zip
I imagine it's not too far from what you want, is it ?
Cheers,
Alban.
587 次查看
zoids
Hi Alban,
Thank you so much...
It's exactly what I want...
Terence
587 次查看
peg
Senior Contributor IV
Search Engine part of Discussion moved to General board.
