How to set a specific variable address
2,542件の閲覧回数
Olivier
Hi everybody,
Does anyone know how to set up a variable at a specific address in CodeWarrior?
I need this to share a variable between two independent softwares (a bootloader and an application) in the RAM of a coldfire.
Thx,
Olivier
6 返答(返信)
726件の閲覧回数
CrasyCat
Specialist III
Hello
Which processor are you targeting (HC08, HC12, Coldfire, MPC82xx, ...)?
Which version of CodeWarrior are you using? To retrieve that info:
  - Start IDE
  - Select Help -> "About Freescale CodeWarrior"
  - Click on "Installed products"
The version number I am interested in are displayed on the top of the dialog.
CrasyCat
726件の閲覧回数
Teckna
Contributor V
I have the same need as Olivier, I use a custom board with K60N512 processor, Codewarrior 10.2 and MQX 3.8.
Many thanks
Teckna
726件の閲覧回数
konrada
You can modify your linker script (.lcf file) and use __declspec in your code to place variables there.
See e.g. https://community.freescale.com/message/97982#97982
The linker script language is also described in the CW build tools user guide, reachable from online help.
726件の閲覧回数
Teckna
Contributor V
I'd not want to create a section for every variable I want to place at specific address: I've read about the syntax:
int var @ 0x60000000 = 5;
 (where 0x60000000 is the address where I want to place the var variable)
but it don't seem to be valid for the Kinetis architecture. Is there any similar syntax valid for the Kinetis architecture?
Many thanks
Teckna
726件の閲覧回数
Teckna
Contributor V
Is there any other suggestion?
Teckna
726件の閲覧回数
konrada
You could go the
#define bla (*((unsigned long volatile*)0x12345678))
way.
