'C' type enums in CW 10.x / Eclipse
796 次查看
ChipBurns
Does the CW 10.x / Eclipse compiler support 'C' type enums?  Some don't (e.g. IAR C++) and even the bracketing:
SomeHeaderFile.h
#ifdef __cplusplus
extern "C" {
#endif
typedef
enum     _SOMEENUMNAME
} SOMEENUMNAME;
#ifdef __cplusplus
#endif
will still fail to compile.
We're currently using CW 5.7.0 (which supports 'C' type enums) and I'm trying to guage the pain of conversion to CW 10.x on this topic.
Thx,
Chip Burns
标签 (1)
1 回复
584 次查看
CrasyCat
Specialist III
Hello
With V10.x we did change from CodeWarrior classic IDE to an Eclipse IDE.
We did not remove basic functionality from the build tools.
So if your classic IDE tools support enumerated types, the Eclipse version should support them as well.
CrasyCat
