16 bit in CW
16 bit in CW
3,692 次查看
ernestsnaith
How do you access only the high and low byte in CW?
Cheers
标签 (1)
3 回复数
1,558 次查看
CrasyCat
Specialist III
Hello
Which processor are you targeting (MPC, Coldfire, HC12, ...)?
What are you trying to do exactly?
Are you trying to access MSByte and LSByte from an address in assembler?
Are you trying to do that in ANSI C?
I need more information to provide an answer.
CrasyCat
1,558 次查看
rhinoceroshead
Try this:
int a16bitNumber = 0x1122;
char* ptr;
char lowByte, highByte;
ptr = (char*)&a16bitNumber;
highByte = *ptr++;
lowByte = *ptr;
Now highByte will hold 0x11 and lowByte will hold 0x22.
1,558 次查看
CrasyCat
Specialist III
Hello
I still need to know the processor you are targeting (HC08, HC12, Coldfire, EPPC5xx, .....)
CrasyCat
