I am using s08pt32 for my project.
I have encountered some problem in r/w to eeprom and flash.
Could you support me with a basic project which could r/w in flash and eeprom of s08pt32 chip?
Basically, I wanted to save the state of the i/o pins before power off and to reinstate these conditions when I power on the chip again.
Appreciate your help.
Thank you and regards,
Javier
解決済! 解決策の投稿を見る。
hi Javier,
We have application note on how to implement S08P Flash and EEPROM.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4570.pdf?fsrch=1&sr=1
the eeprom and its management method is the same for all 9S08P family.
I also attached the sample code.
hope this helps!
this answer is for you, if it helps, please click on "correct answer " button. thanks!
ZhangJun
hi Javier,
hope this helps!
ZhangJun
