array of chars from array of array of chars
730 次查看
GMVS
hello
i got a bidimensional array of chars
assume it looks like this
const char array[3][17]={"mary",
                                      "has a",
                                      "lamb"};
1) can i safely assume the matrix is gonna end like this?
012 345678910111213141516
mary/0
has0x20a/0
lamb/0
assume i have a function like this
void function(char something[]);
2) is there any easy way to send just the second row of array to the function??
because if i write
function(array[1][0]);
this thing is gonna break
3) or should i make a new unidimensional array, copy the info from the other to this one with a for cycle and then send it?
thanks
edited by: GM VS syntaxis
586 次查看
bigmac
Specialist III
1. When initialising the array, the individual strings will need to be separated using commas, and the array definition should end with a semicolon.
char array[3][17] = {"mary",  "has a", "lamb" };
If you are expecting the array data to be located within flash memory, you will need to use the const modifier.
2. The function is expecting a pointer to the first element of a single dimension array.  To send the second element of the two-dimenional array to the function you can use array[1] as the parameter.  This should give identical results to the alternative &array[1[[0].
Mac
587 次查看
bigmac
Specialist III
Mac
586 次查看
GMVS
yey!
thanks a lot
if i had to make fors for every time i want to use the routine i was gonna waste a hell of time
:smileylaugh:
