Hi everybody;
I'm in trouble with tx interrupt.
although i wrote codes below it's not working
__interrupt void isrVscitx(void){ if(SCIS1_TC){// wait to Transmission Complete flag txCount++; if(txCount>10){ //to transmit 10 bytes txCount=0; txON=0; //TX hardware enable pin low SCIC2_TCIE=0; //TX interrupt disable } else{ SCID = sendBuffer[rxCount]; } }}
The problem is:
Even TXInterrupt is off it branches to interrupt again and again.
If i use debugger step by step code enters txCount control block but if i set a breakpotint to
txCount=0;
line it never enters to breakpoint.
It's so meaningles.
Hi.
First of all, if you want to send the first 10 bytes in your array, your code starts on element 1 instead of element 0 of array.
Use Transmition complete like event generator of interrupt doesn't take advantage of SCI module, because we could use the TDRE flag in order to queue new data on SCI module.
So you could use two posibles flags as interruption generators
1.Transmission Complete flag
2. Transmit Data register empty flag
Example to first option:
SCIC2_TCIE = 1; //Call this to start transmission
if(SCIS1_TC)
SCID = sendBuffer[txCount];
if(++txCount>=10)
SCIC2_TCIE = 0; //Disable interrupt
txCount=0;
//txON=0; //TX hardware enable pin low
Example to second option:
SCIC2_TIE = 1; //Call this to start transmission
if(SCIS1_TDRE)
if(++txCount>=10)
SCIC2_TIE = 0; //Disable interrupt
txCount=0;
The above examples assumes that you starts correctly the SCI module.
Greetings @420
The first example here also suffers from the fact that it needs to be "kick started" by loading the SCID from outside the interrupt, otherwise TC will never be set to generate the interrupt.
IMHO, it is misleading to satisfy the flag resetting requirements by doing an "if" test of the generating flag inside the ISR. To a reader it looks like the if needs to be there and looks like you could tack an "else" condition on the end (which you can't). dummy= SCIS1 even uncommented, will cause the ignorant reader to find out why, rather than lull them into a false reason.
I presume that the first character is sent from outside the ISR. Then each time the ISR is entered the TC flag will always be clear since a new character is sent each time. I also notice that your are using the index value rxcount, rather than the perhaps expected txcount, and that you do not increment this index value. So it is possibly the same character sent each time.
If you require to limit each transmission to ten characters, you will need to keep track of this within the else part of your if statement, and then use the TC flag to determine only when the interrupt should be disabled.
Mac
The following untested code snippet is what I was alluding to in my previous post.
volatile byte sendBuffer[11];
volatile byte txCount;
void SCI_send_string( void)
txON = 1; // Enable Tx hardware
txCount = 0;
while (!SCIS1_TDRE);
SCID = sendBuffer[txCount++]; // Send first character
SCIC2_TIE = 1; // Enable TDRE interrupts
if (SCIS1_TC) { // Test for transmission complete
SCIC2_TCIE = 0; // Disable TC interrupts
txON = 0; // Disable Tx hardware
else {
if (txCount < 10)
else {
SCIC2_TIE = 0; // Disable TDRE interrupts
SCIC2_TCIE = 1; // Enable TC interrupts
Mac
Hello longliveboy,
You have not told us what flag you have setup to trigger the tx interrupt!
I'm guessing you have set it up for TDRE. Now when the interrupt is triggered TC is not set yet so nothing is done and you have failed to properly clear the TDRE flag.
Perhaps a review of the datasheet is in order for you....
Perhaps you could also indicate what you are trying to do, because it is not clear from your supplied code.
Peg;
I have tried both Transmit Interrupt(TDRE flag) and Transmit Complete Interrupt(TC flag) separately but result is same.
First tx interrupt is triggered in main function by "SCIC_TCIE=1;"
I read datasheet carefully but i dont know what is the point that i miss?
I'm trying to implement MODBUS protocol
i recieve some requests from server and start to control frame compability for modbus. If all frame is ok i start to transmit requested datas but tx interrupt never stops.
Hi again,
Try setting the interrupt to trigger on TDRE and remove the TC test from within the ISR. Put in a read of SCIS1 at begining of ISR to allow the flag to clear. That should get you started.
