Hi everyone,
i am trying to do an echo test with so8dz60, i have done with transmitting data but,
while i am debugging code by enabling transmit and receive interrupts code is exiting from debug session.
can any one help me to come out of this issue.
Thanks for you help in advance.
please help me and if any example code is there for this it will be very helpful for me.
已解决! 转到解答。
I have attached a CodeWarrior V6.3 sample that set the SCI at 14400 bps using the default bus clock 8MHz, this program send the same information +1 that the received information. I hope this will help you.
