MCP11 toolchain?
MCP11 toolchain?
823 次查看
ALawrence
Is there a downloadable C compiler / IDE for the MCP11A1CFNE3 part? I couldn't find any reference to this part in any of the Codewarrior packages that are available on the site.
We need to do a code tweak on a legacy product and don't have this toolchain available (all we have is the source right now).
421 次查看
celsoken
Contributor V
It seems to me like a legacy PLCC52 HC11 P/N.
I've got some legacy tools for that, I think it was Avocet compiler.
I hope it helps,
Celso
421 次查看
ALawrence
Thank you for the reply.
I don't think it was the Avocet compiler or the GCC toolchain. I have only these clues from the source archive:
1. No discernable project files.
2. Some files called DEFAULT.ENV which contain the following:
   LIBPATH=c:/arch11/lib
   GENPATH=../h;c:\arch11\lib
   ERRORFILE=ERRFILE
3. Some GNU-ish makefiles:
   CC = chc11
   CPP = cpp
   ARCH11 = arch11
   LINK =  linker
   ASM =  ahc11
Some web sites that I've visited imply that chc11 -> HIWARE -> Archimedes -> Metrowerks -> Freescale, but I can't find any downloads from Freescale for the HC11 family.
421 次查看
celsoken
Contributor V
You're right, at this time Motorola did not provide free C compilers, except a smallc compiler w/ source code included.
They only provided freeware assemblers, command-line type. Later they added some shell IDE.
I don't think Freescale will provide you a legacy compiler for HC11.
I could help you patching this code but I'm overloaded, sorry!
Cheers,
Celso
