MC9S08AC32 Baking temperature, Soldering information
708 次查看
caesar_song
Hi Would you kindly help to provide the MC9S08AC32 Baking temperature, Soldering information,thanks
696 次查看
vicentegomez
if you check the following link you can find all the package options for the S08AC devices,
https://www.nxp.com/products/processors-and-microcontrollers/additional-mpu-mcus-architectures/8-bit...
all of them are lead free I will take just as an example the MC9S08AC8MFGE that is a LQFP 44
on this link you will see that the peak of temperature is 260 C and this device is MLS 3
https://www.nxp.com/part/MC9S08AC8MFGE#/
so for the soldering we have the followin application note
https://www.nxp.com/docs/en/application-note/AN3300.pdf
Regarding to baking you need to follow the
IPC/JEDEC J-STD-033 Bake Conditions
and depending the package that you are using is the time and the temperature that you need to use
