MC9RS08KA2
MC9RS08KA2
1,475件の閲覧回数
jorgehoraciogon
I can´t download a empty program to my uC. The hardwire is well done, but Codewarrior cannot be communicate with the uC. What is it happening? The uC it is MC9RS08KA2
4 返答(返信)
1,342件の閲覧回数
trytohelp
Hi Jorge,
This is the configuration used on my side:
    CW for MCU v10.6.4 + patches
    TWR-ELEV + TWR-S08UNIV + TWR-RS08DC-KA8
Under CW for MCU v10.6.4 I've created an example for KA8 for OSBDM and P&E connection.
I can connect the TWR-S08UNIV using P&E Multilink Universal Rev B  and the example can be downloaded without problem.
Now for the OSBDM, it's another story ... I get some problems.
However on your side it seems you're using P&E interface and not OSBDM.
Using P&E Multilink Universal Interface I can download the application without problem
Pascal
NXP Technical Support
1,342件の閲覧回数
jorgehoraciogon
Hello Pascal!
But I still can´t solve the problem. I´m adding a pic of the hardwire.
The uC is it new, but I think it could be a problem with the Multilink.
Also, I can see the driver in the Device Manager of Windows and appears is it working well.
Why CW can detect the Multilink and can´t be communicate with the uC if this is new?, do I need to change the Debug Configuration in the CW?
I remark, when I created the Boreboard Project, I selected the right options.
Thanks!
1,342件の閲覧回数
trytohelp
Hi Jorge,
Do you have an eval board to test the configuration ?
It could be fine to test the configuration (codeWarrior + Multilink).
On my my side it's working fine using Tower kit.
I don't think there is a problem with the Multilink as the 2 leds are switched-on.
The Multulink is detected by CodeWarrior following the Error.png file.
I think there is a problem between the Multilink and the device and this explain the error2.png file.
Most of the time, the message "error2.png" occurs when a wrong power supply is provided on-board or when the Multilink is not correctly connected to the board.
This question is may be more for hardware colleague.
I will move the question to them.
Pascal
1,342件の閲覧回数
jorgehoraciogon
Thank you Pascal!
I solved the problem. I downloaded the firmware again and I could burn the uC.
Multilink can't program different families of uC before download the correct firmware.
Thank you and I expect this can help someone else in the future.
Have a great day too!
