How to put s08 Microcontroller in sleep mode(stop3) and wakeup it?
583件の閲覧回数
mehdializadeh
I am using mc9s08dz96 microcontroller with 8 MHz external clock osc. I have read This document and I have try to write a function, When the timer value reaches a certain value, the function is executed and I expect the microcontroller to go to stop3.
First I try to set this register:
void stop3(){
	setReg8(SPMSC1, 0x14U);
	setReg8(SPMSC2, 0x00U);
	setReg8(SOPT1, 0x23U);
	setReg8(MCGC1, 0x04U);
	setReg8(MCGC2, 0x26U);
 With this function, the power consumption did not decrease. I tried to set the registers in more detail with the help of datasheet .
void stop3(){
    MCGC1_IRCLKEN = 1;
	SPMSC1_LVDSE = 1;
	SPMSC1_LVDE = 1;
	SOPT1_STOPE = 1;
	SPMSC2_PPDC = 0;
	SPMSC1_LVDRE = 1;
	SPMSC1_LVWACK = 1;
	SOPT1_STOPE = 1;
	MCGC1_IREFS = 1;
	MCGC2_ERCLKEN = 1;
	MCGC2_EREFS = 1;
	MCGC2_HGO = 1;
	MCGC2_RANGE = 1;
But this code didn't work either. Does anyone have experience doing this?
Thank you in advance.
2 返答(返信)
560件の閲覧回数
vicentegomez
To enter stop mode(stop2,stop3),just use the following instruction:
_asm stop;
You can place these to instruction at wherever you want.
The stop mode configuration is determined by SOPT1:STOPE ,this bit should be enabled to enable stop mode SPMSC2:PPDC,configure to enter stop2 or stop3
Notice:If you want to enter stop2,you should disable the LVD or you will enter stop3.After wake up from stop2,you shold clear the PPDF by write a one to PPDACK.
547件の閲覧回数
mehdializadeh
Thanks a lot for your reply,
I set this register:
void _EntryPoint(void)
  setReg8(SOPT1, 0x20U);
  setReg8(SOPT2, 0x00U);
  setReg8(SPMSC1, 0x1CU);
  if (*(uint8_t*)0xFFAFU != 0xFFU) {
    MCGTRM = *(uint8_t*)0xFFAFU;
    MCGSC = *(uint8_t*)0xFFAEU;
  setReg8Bits(MCGC3, 0x10U);
  setReg8(MCGC1, 0x9AU);
  setReg8(MCGC3, 0x14U);
  setReg8(MCGT, 0x00U);
  while(MCGSC_OSCINIT == 0U) {
  while(MCGSC_IREFST != 0U) {
  while((MCGSC & 0x0CU) != 0x08U) {
  setReg8(MCGC2, 0x2EU);
  setReg8(MCGC1, 0x92U);
  clrReg8Bits(MCGC3, 0x10U);
  setReg8(MCGC3, 0x44U);
  while(MCGSC_PLLST == 0U) {
  clrReg8Bits(MCGC2, 0x08U);
  while(MCGSC_LOCK == 0U) {
  setReg8(MCGC1, 0x12U);
  while((MCGSC & 0x0CU) != 0x0CU) {
  __asm   jmp _Startup ;
But the command "__asm stop;" in main(), has no effects. The project file is attached.
Thank you
