How many times code can be flashed in PT2000 controller ?
agkulkarni94
Is there any limitation on the number of times flashing the code into Pt2000 controller and if there is then, how many times?
vicentegomez
The memory type implemented for microcoding storage, data storage, and configuration register is volatile. I’m not aware of any limitation regarding how many time it can be programmed.
I hope this will help you.
