Floating-point Math problem, MC9S08PT60
589件の閲覧回数
AndreiLuchuk
Having an issue I can't resolve, the following lines of code cause a reset
   FLOAT32 fPct100 = 100.00;   FLOAT32 fPct18  = 18.00;   FLOAT32 fPvPercent;    FLOAT32 fBarGraphPercent;   UINT32  nBarGraphSegment   = 0;   fPvPercent = gfPVPercent * fPct100;   fBarGraphPercent = (UINT32)(fPvPercent / NUM_BG_SEGENTS);      //fPvPercent = 20.0000;      fPvPercent = (fPvPercent / fPct100);      //problem here      fPvPercent = fPvPercent / fPct18;         //problem here
 it is possible to step through this statement and hit brakepoints at the end of main loop. however, running is not working. i can't catch the reset with Cpu_OnReset either.
Using CWIDE 10.2 with the latest updates.
any suggestions are greatly appreciated.
3 返答(返信)
394件の閲覧回数
CompilerGuru
Make sure you are not running out of stack. Increase the STACKSIZE in the prm file
(not sure where to set the stack size with Processor Expert).
394件の閲覧回数
AndreiLuchuk
Thanks for looking in, Daniel.
I've increased the stack from 0x0080 to 0x0500, but no solution. How much stack does this need?
394件の閲覧回数
CompilerGuru
Not that much :smileyhappy:.
Thought 0x80 feels a bit low when using floating point arithemtic.
To see how much stack it needs, search for STACKSIZE in the forums. Also one way:
https://community.freescale.com/message/115600#115600
Another cause might be the COP/watch dog timer, try disabling it temporarly to see.
Otherwise, I would recommend to create a small example app showing your issue.
