Debugger for OSEK turbo application
1,400 次查看
tupham
Dear all,
I have installed Code Warrior for HC(S)08 v5.1 and OSEK turbo v2.3. I have built sample for HC08GZ60 which is available after installing OSEK turbo. I have followed steps to build that sample application and generate all necessary files in 3 folders: bin, gen, obj. Especially in bin, I have the executable file "sample.hex" and the link file "sample.map". But till now, I don't know what the "debugger" is. Is it Code Warrior v5.1? I can't find how to use the debugger in Code Warrior v5.1 to execute that OSEK application. Please help me.
Thanks anyway,
Tu Pham.
327 次查看
CrasyCat
Specialist III
Hello
What happens if you select Project -> Debug?
This should load code on the target and start the debugger.
CrasyCat
