Clock Cycles for Branch Instructions
2,533 次查看
Nevo
I'm porting my mind from the world of PIC chips to HCS08.
In the PIC world, a conditional branch instruction takes so many clock cycles to perform, plus a few (2, I think) additional cycles if the branch is taken.
I don't see the same documented in the HCS08 instruction set. Does a conditional branch instruction take the same number of cycles whether or not the branch is taken?
Nevo
5 回复数
580 次查看
Alban
Senior Contributor II
Hello !
I would advise the S08 CPU Reference Manual which details every intruction available and their access.
Page 145 will interest you.
HCS08RMV1
HCS08 Family Reference Manual
Cheers,
Alban.
580 次查看
Nevo
Thank you, gentlemen!  (Alban, I was indeed reading that reference.)
So in a CodeWarrior disassembly, I see this (I wrote the code in assembler):
Code:
829:      CPX m_ChannelDimValue:20;  0096 c30014   [4]             CPX   m_ChannelDimValue:20  830:      BNE testCh21;  0099 2602     [3]             BNE   L9D ;abs = 009d  831:      ORA #16;  009b aa10     [2]             ORA   #16  009d          [5]     L9D:      832:    testCh21:  833:      CPX m_ChannelDimValue:21;  009d c30015   [4]             CPX   m_ChannelDimValue:21  834:      BNE testCh22;  00a0 2602     [3]             BNE   LA4 ;abs = 00a4  835:      ORA #32;  00a2 aa20     [2]             ORA   #32  00a4          [5]     LA4:      836:    testCh22:
What is the [5] on the lines with the L9D: and LA4: labels?  I'm trying to figure out what instruction there takes 5 clock cycles.
580 次查看
Encoder
The disassembled sample is fairly cryptic, I suspect not being correctly formatted with too many line feeds.
No istruction in this sample is longer than 4 cycles (CPX opr16a)
L9D  and  L4A are alternate labels for  testCh21:  and  testCh22
It seems to me that [5] is the alternate clock counting to reach the label when the branch is not performed and the intermediate instruction (ORA #opr8i) is done.
580 次查看
Nevo
Thanks, Encoder.
It was a good hypothesis.  I tested it by adding NOPs to my code but the pesky [5] by the label remains.
I see, however, that there's a separate forum for CodeWarrior issues, so I'm going to drop this thread and start a new thread in the CodeWarrior forum.
580 次查看
bigmac
Specialist III
Hello Nevo,
Yes, three bus cycles whether or not the branch is taken.
Mac
