AF_DataRequest and memory management
1,567 次查看
CecchiSandrone
I want to know what's the memory management of buffers while calling AF_DataRequest because I'm encountering some "out of memory" errors from it. Who is responsible to free the buffer?
4 回复数
380 次查看
Mads
Contributor V
Cecchi,
you question is very general and would not be easy to answer.
I would recommend that you re-visit our documentation and read how the AF_DataRequest should be used.
But, to try and solve you issue:
When you do a AF_DataRequest, wait for the confirm before you initiate the next transmisison.
This will insure that you do not stavate the system.
BR,
Mads
380 次查看
CecchiSandrone
BR,
Mads
Yes Mads, I understand this. I can't catch only who is responsible to free the buffer that contains the message to send. Furthermore, is there a "unreliable" way to send data without waiting for confirm?
380 次查看
Mads
Contributor V
when you "pass on" a buffer, the layer you pass it to is responsible for the free'ing.
You only have to free when you receive - just like the demo application shows.
BR,
Mads
380 次查看
CecchiSandrone
Ok...now is clear! Thanks again for info Mads.
