AC60 Flash size - is the datasheet wrong?
800件の閲覧回数
patsko
I'm beginning to work with the S08AC60 and I found out that the datasheet (latest version: Rev. 3  8/2011) is conflicting about its Flash size.
At section 4.4.1, the datasheet says:
      MC9S08AC60 — 61268 bytes (120 pages of 512 bytes each)
But looking at figure 4.1 (at the beginning of section 4.1) and calculating the Flash size based on the memory map, I came out with 63.280 bytes and 124 pages.
I also haven't found any errata about this on the MCU documentation.
Just as a comparison, I looked for the datasheet of a similar MCU (S08AW60) and it seems to be right, showing the Flash size as 63.280 bytes and 124 pages.
Can I assume that the S08AC60 datasheet is wrong and its Flash size is 63.280 bytes?
タグ(3)
648件の閲覧回数
david_diaz
Hello Luis Fernando,
It certainly looks like a documentation error.
In this case, the Figure 4-1 from the Reference Manual shows the correct information:
MC9S08AC60 FLASH Size: 63280 bytes.
I based my response on its corresponding .prm file:
ROM                       =  READ_ONLY 0x1860 TO 0xFFAF;
            ROM1                     =  READ_ONLY 0x0870 TO 0x17FF;
Hope this information will be useful for you.
Have a great day.
David Diaz.
649件の閲覧回数
david_diaz
Have a great day.
David Diaz.
