32.768K external crystal can't work in MC9S08QG4
484 次查看
wangbaode
hello ,
I want to use RTI in MC9S08QG4 and use external clock as RTI clcok.
so I connect a 32.768K crystal as the picture.but it can't work.
RF = 1M,C1=C2=18pf.
my code is as follow:
    ICSC2_ERCLKEN = 1;//enable external clock as erclk
   ICSC2_EREFSTEN = 1;//enable erclk in stop mode
    ICSC2_RANGE = 0;//1==.high frequency,0=>low frequency
    ICSC2_EREFS = 1;//1=>select osc as external clock source
    ICSC1_IREFS = 0; //0=>external clock is selected,
    ICSC1_CLKS = 2; //0=>out of FLL is selected,2=>external clk is select
    ICSC1_RDIV = 0;// 0=>prescale ==1
    ICSC2_BDIV = 0;
    while(!ICSSC_OSCINIT);
标记 (4)
359 次查看
wangbaode
hi,
I make a mistake in hardware.
when i change RF to a 10M resistor,my program can work well.
360 次查看
wangbaode
hi,
