We are using USB TAP (900-75116; REV A; 01001362) to debug (via CodeWarrior) and to program (via 56800E Flash programmer) our target DSP 56F8355. CodeWarrior IDE version is 5.9.0 (build 4713) on Windows XP.
Unfortunately, I no longer can program or debug our target:
Could you please help to fix this issue.
Thanks in advance for your help.
I guess you didn't get any help with this problem. I'm having the same problem with a device that has run smoothly for the last 10 years.
Could you please help to fix this issue. I have meet the issue,
