IAR tools,Flash demo,when run to the FTFE->FSTAT = FTFE_FSTAT_CCIF_MASK;the mcu will reset,how can you solve the problem.
take a look at this thread:
https://community.nxp.com/thread/453849
The code must run from RAM when programming PFLASH. This could be the root cause of your problem...
Lukas
thank you for your suppoport,i will try to do it
best regards!
