Hello NXP, I downloaded the new MCUXpresso IDE. It looks like everything loaded OK. I can build a project but when I click on Debug 'lpcxpreso54608_demo_apps_ I get an error message - No compatible probes available. They may be disabled, disconnected, not powered, already in use or not compatible with this target. I've checked the board where the jumper is supposed to go and it's installed but I think the board might be damaged. i got a used one from the Avnet FAI conference. Could that be the issue? Do I need a new board?
Hi Daniel,
Please can you review the information at the Getting Started tab on the board page: http://nxp.com/demoboard/om13092 just to make sure you have steps understood.
A few things to check:
Sometimes it takes some time for the drivers to enumerate the first time the board is plugged in. After attempting the debug connection try power cycling the board and see if a Windows "Installing software" message appears in the boot right corner of your screen.
