Set TOP field in SNVS_LP Control (LPCR), which will trigger i.MX6 PMIC_ON_REQ with the Dump PMIC enabled.
If board hardware allows it - it is possible to use i.MX6 PMIC_ON_REQ signal
to switch off external PMIC.
How to control the PMIC_ON_REQ pin by SW without ON/OFF pin for i.MX6
Yuri.
Hi GregT
For proper answer and discussion, Please check:
https://community.nxp.com/thread/307212
